Zip Code Field Wording Issue
I have the zip code field as required on my availability form, but the grey subtext states “5-digit (if known)”. This is a required field for me, so the wording should not include (if known).
Hi @dobby10,
Thank you for bringing this to our attention! The wording “5-digit (if known)” in the zip code field can indeed be confusing if it’s marked as required. Unfortunately, the documentation does not specify how to change that particular subtext.
I recommend reaching out to our support team directly for further assistance on this issue. They can help clarify if there’s a way to adjust the wording to better fit your needs.
If you have any other questions or need further assistance, feel free to ask!
