PDF not working
Tried to create PDF of document and received message stating "Fail to generate PDF invalid HTML which usually means missing image. I tried to create a PDF on an invoce previuosly created and received the same mmessgae
Hi @stickman,
It sounds like you’re encountering a common issue when generating PDFs. The error message “Fail to generate PDF invalid HTML” often indicates that there might be a missing image in your document.
Here are a couple of things you can check:
  1. Ensure that all images, including your logo, are uploaded correctly in Setup → Company Information.
  2. Make sure you have selected “Company Logo” instead of “Company Name” for the logo setting.
If you’ve confirmed these settings and are still having trouble, please reach out to our support team for further assistance. We’re here to help!
I have no images on this document just words
Ashley, create a support ticket – stickman, post next time in Bug Reports as they immediately turn into a ticket. Thanks both!
@stickman — Great news! The PDF generation error you were experiencing has been fixed. Our team identified a regression in the PDF generator’s error-checking logic and deployed the fix to all Gigbuilders as of May 22, 2026.
Please try generating a PDF again from your document — it should work smoothly now, even without any images. If you run into any more issues, just let us know!
— Ashley, Gigbuilder Support
