Your live PayPal Client ID (AZB2RUZXcgRh6ioXwIIwaYy2evrrIje7IgJPxJrEesUYW6HCBgW2UHXWwTSg_bb2JXOCzF4WFA0u7JCn)
A quick note that the Merchant Services page shows “Use PayPal = Yes” but PayPal never appears in the processor dropdown
Hi @djscottreed,
It sounds like you’re having trouble with the PayPal integration in Gigbuilder. Based on the documentation, here are a few steps to ensure everything is set up correctly:
- Generate a PayPal app: Make sure you’ve created a free PayPal app and have your Client ID ready.
- Set “Use PayPal” to Yes: Confirm that this option is enabled in your Merchant Services settings.
- Check the Processor Dropdown: If PayPal is still not appearing in the dropdown, it may be helpful to double-check that you have entered the correct Client ID and that you are in the correct mode (sandbox vs. live).
If you’ve followed these steps and are still experiencing issues, our team is here to help you further!
Yes. Did those steps.
LIVE KEY - AZB2RUZXcgRh6ioXwIIwaYy2evrrIje7IgJPxJrEesUYW6HCBgW2UHXWwTSg_bb2JXOCzF4WFA0u7JCn
Paypal doesn’t show in merchant integration
Hi @djscottreed,
It sounds like you’ve followed the initial steps for integrating PayPal, but if PayPal isn’t showing up in your merchant integration, please double-check the following:
- Ensure that you’ve generated a PayPal app and have the correct Client ID entered.
- Make sure that “Use PayPal” is set to Yes in your settings.
- Confirm that you are using the correct environment (sandbox vs. live) for your keys.
If everything seems correct and you’re still having issues, our team is here to help you troubleshoot further.
Feel free to reach out with any additional details!
I’m just catching up from the agents – I logged in to your GB, picked an event, went to client center, went to pay, option was there for paypal – all looks fine.
