Thanks for following up! It sounds like you’re experiencing some issues with the additional documents in Event Prep.
From the documentation, it seems that documents marked with Event Prep visibility are bundled into 1-touch event printouts, which should help streamline your process. If you’re only seeing half the page load when printing, it might be a temporary glitch, but using the PDF option seems to work correctly for you.
Regarding customizing the print order of Event Prep forms, the documentation doesn’t specify this feature. However, I recommend reaching out to our support team directly for further assistance on this matter.
If you have any other questions or need more help, feel free to ask!
