We are adding another possible playlist to the events for the DJ to select music – this will not be shown to the client, but will appear on printouts OR crates you simply drop into Virtual DJ.
The list will be available when you open a music chart – you’ll select the event (optionally) and selected music will appear in that category.
OPTIONALLY you’ll have an AI button which will auto-populate the list using the client’s must play, should play, and don’t play songs.
