Is there a way to customize the gigbuiler client login background? Login to your Event just currently has a white background.
Thank you …
Thank you …
Hi @dahauss,
Yes, you can customize the background of the Gigbuilder client login! You have two options:
backgroundURL field.To set this up, navigate to the Client Options in your Gigbuilder settings.
If you need further assistance with the upload process or anything else, feel free to reach out!
I did that and it is not customizing the background.. just white is all I get
Hi @dahauss,
It sounds like you’re having trouble customizing the background for your client portal. To set a background image, you can either choose from the preset options like “Blue Party” or “DJ Background #1,” or you can upload your own custom image using the backgroundURL field.
If you’re still seeing a white background after trying these options, it might be worth checking if the custom image upload was successful or if there are any other settings that need adjustment.
If you need further assistance, feel free to reach out, and our team will be happy to help!
I tried one of the stock backgrounds as well as uploading one. Just a white background.
Looks like uploading a custom image does not work. WHat is the specific dimensions it needs to be in order to work?
