PDF Files do not render properly
When sending things as PDFs, such as contrats, they do not render properly. This has been the issue forever, and I thought @Scott was going to fix. For example, bullets on Lists do not show up properly and the entire page does not format properly. If you send it not as a PDF, its file as it always has been. My username is dahauss and the event I was using this in is the JUNE 18 Event.
Hi @dahauss,
I understand that you’re experiencing issues with PDFs not rendering properly, particularly with bullet points and formatting. While the documentation doesn’t specifically address PDF rendering issues, it does mention that using “Event Prep” visibility for documents can help ensure they are formatted correctly for events.
If you continue to face these challenges, I recommend reaching out to our support team directly for further assistance. They can provide more tailored help regarding your specific situation with the June 18 Event.
Let me know if there’s anything else I can assist you with!
@admins Scott was supposed to fix this
