CheckDate Script returning 404
Followed instructions to add a button, completely unresponsive. The console shows 404 not found error.
Failed to load resource: the server responded with a status of 404 () https://tpa.gigbuilder.com/cal/nj/coastaldjs.nsf/rss_qmdb?open&cors=1&A=21&S=
This is also happening in the sandbox.
I’ll take a peek at this today. We’ll have you up and running by sundown.
What button are you trying to add? Give me steps you took to create the button so I can find and fix for you.
Hi! I was using the check date button.
I added this to the head file in the theme files (i’m using WP)
<script src="https://www.gigbuilder.com/cal/nj/coastaldjs.nsf/webtools.js?open"></script>
Then I added this to the page:
<button class="gbCheckDate">Check Availability</button>
I left a button un hid for you so you can see the behavior: Packages – Coastal DJs
@admin Following up, see above!
@admin following up on the above
